98 Warrior 350 clicking noise
Old Jun 4, 2009 | 04:45 PM
durga87's Avatar
Default 98 Warrior 350 clicking noise
Hey guysi bought a warrior about 7 months ago and it was in 10 different pieces and i finally got it back together and now it makes a horrible clicking noise that is coming from the motor it self. I did a valve adjustment to spec so that should be all set but its still making it. Should i just ignore it or what. Help me out please.
Old Jun 4, 2009 | 05:51 PM
Kevin R.'s Avatar
That's somthing you don't want to ride!! If you do you may break somthing internal and damage other parts. I would try to locate what area of the engine and do some investagating to find out what's going on. You've done 7 months work to not get it done right, one more won't hurt. Good luck!
Old Jun 4, 2009 | 06:19 PM
webbl19's Avatar
Is it a ticking noise? My vavles tick and from what i can tell it is normal on a warrior. Mine are not loud though.
Old Jun 4, 2009 | 07:38 PM
durga87's Avatar
Default 98 warrior 350 clicking noise
Sounds good i am looking into it I wasnt sure if it was a popular thing to go wrong on older warriors but i thought i would check and yes it is a pritty loud ticking. Any tips to locate where its coming from using a wood pole All i can tell is that its coming from the motor put all parts of it sound the same.
Old Jun 4, 2009 | 07:55 PM
webbl19's Avatar
does the click get faster when you give it gas?
Old Jun 10, 2009 | 11:43 AM
Stalefish's Avatar
I have this same issue, but its a Polaris Trail Boss. Some clicking noise coming from the motor I assume, only at accelleration, not at idle, and only in gear. Problem didn't surface till after I replaced the spark plug...
Jay-
Old Jun 10, 2009 | 12:18 PM
wheily's Avatar
i would check to see if ther is play in timing chain . tenshioner might be worn out
Old Jun 10, 2009 | 12:21 PM
webbl19's Avatar
Jay-
did you put in the right spark plug?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
