Got a warrior issue
Old Jun 4, 2009 | 08:51 PM
webbl19's Avatar
Default Got a warrior issue
Ok so i got a parking brake block off plate installed it and took out the cable. I got a new clutch lever and perch. Also changed the front sprocket to a 12t.
That is all i have done, before it was fine.
Now the issue. Starts in neutral only. Will not start when it is in gear. Then when it is started i go to put it in reverse and it shuts off.
I do know there was a plug on the old clutch lever. I was assuming this was the parking brake sensor everyone always talks about cutting off. Well i left it together for the most part, i broke it when i was getting it off and all the little peices inside fell out and i have since swept the garage. But i left the plug deal there and stuck it down the steering stem.
So was that some other kind of sensor i need or is there something i am missing?
Old Jun 4, 2009 | 08:53 PM
webbl19's Avatar
Ok just looked up the plug, bike bandits fiche calls it a stop switch assy.
Old Jun 4, 2009 | 09:28 PM
Terrellster's Avatar
Should be a TORS switch. The switches are normally closed I think. If you just tucked the connector without connecting the wires together, your bike thinks the TORS switch has the park brake on all the time..... having a hard time accellerating? or have you not tried that stuff yet?
I could be absoloutely backward on this but that's what I remember..... I have a Blaster with the TORS.... It is jumped and inop, I'll have to check tommorrow if you still need help.
Old Jun 4, 2009 | 09:35 PM
webbl19's Avatar
no problems accelerating.
so should i splice the wires together?
Old Jun 4, 2009 | 09:43 PM
webbl19's Avatar
Ok i got it figured out. I just unplugged the wires under the grill and plugged them back into eachother. I guess showing it a closed circuit.
Old Jun 4, 2009 | 10:40 PM
tnwarrior82's Avatar
thats funny on mine i never tied the wires together and it runs great.do u guys think it would do better if i tied them together
Old Jun 5, 2009 | 06:28 AM
if you're doing fine on accelleration, then don't splice 'em together. I have my brain twisted (or my wiring is different). I had a 2006 and a 89 blaster. I just couldn't remember the details.
Old Jun 5, 2009 | 06:53 AM
95wolv's Avatar
Just FYI, there is no TORS on the Warrior, that was only on the Blaster and Banshee,totally different carb.
Old Jun 5, 2009 | 10:23 AM
webbl19's Avatar
well i like reverse so i had to plug the 2 wires together (didnt really splice, there is a male and female connection under the grill part). without doing that it shut down when i put it in reverse.
all is good now.
Old Jun 5, 2009 | 08:26 PM
all is good now.
Excellent info you and 95wolv. I'll keep all that in my brain somewhere.
So many have had so much issue with the TORS, I kinda thought it was typical on all the Yamaha's
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
