Will a 27" tire fit w/o a lift?
Old Jun 5, 2009 | 09:13 AM
arsonfnder's Avatar
Question Will a 27" tire fit w/o a lift?
Looking to put 27 10/12 on the front and 27 12/12 on the rear, will they rub or scrape on a stock 06 Sportsman 500 efi?
Old Jun 5, 2009 | 10:56 AM
Kerbbirds's Avatar
will rub the tie rod end.
Old Jun 5, 2009 | 12:10 PM
arsonfnder's Avatar
Will a lift kit resolve the tie rod rub or a narrower tire? Thanks a bunch.
Old Jun 5, 2009 | 04:10 PM
slikjr's Avatar
In the rear, you'll be fine. I ran a 12.5" wide with no issues. In the front, any wider than 8" and you're going to rub. The height, you'll be fine. You either have to use a wheel (rim) with a different back spacing or get wheel spacers.
Old Jun 5, 2009 | 07:16 PM
midcity mudder's Avatar
Default Your 27" tires ?
Hi, I would purchase a small lift by High Lifter they sell them for about 120 bucks, that would give a little more clearance in the front especially, because when you hit a bump they will rub a little but nothing serious, plus it looks cool. Will also need to purchase a wheel spacer kit to offset the front tires so they do not rub. I would put some at the rear aswell so it don't track funny in the mud. Happy Trails
Old Jun 8, 2009 | 03:15 PM
1M800's Avatar
Flip the tie rod ends over and they might clear. I also had to put a washer on each wheel stud behind the wheel so they didn't rub on the springs. I also ground down a little "nub" on the strut.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
QuadRiders
Oct 22, 2015 04:13 PM
cboler9
Sep 24, 2015 08:35 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
