Gas leaking
Old Feb 17, 2001 | 11:57 AM
dawarriorman's Avatar
ok, i cant figure this out, but then again i try not to let it happen all that often. whenever my warrior gets stood up on the grab bar, it starts leaking gas from somewhere all down the airbox and into where the battery sits. anybody know why?
Old Feb 17, 2001 | 02:17 PM
hot_shoe_cv's Avatar
Are you shutting off the petcock on the tank? At the angle you have it it may be coming from the breather hose on the fuel cap.
Old Feb 17, 2001 | 04:26 PM
thats the one thing i know for sure, its not coming from the vent hose, and petcock isnt really an option, cuz im talking more like when i go to far on a wheelie or something like that, and stand it up.
Old Feb 17, 2001 | 04:41 PM
springdrl's Avatar
I may be missing something here, but couldn't the odd angle be causing the float valve to open in the carburtor?
Old Feb 17, 2001 | 05:07 PM
Yeep's Avatar
thats from the breather hoses on your carb, no big deal.
Old Feb 17, 2001 | 08:25 PM
trailboss450's Avatar
25 Year Member
If you are standing it nearly straight up it is coming from the carburetor vent hose. The float is unable to function and stop the flow of gas when it is at that steep of an angle. It allows the carburetor to overfill and the vent hose is the only place it can go.
Old Feb 17, 2001 | 10:00 PM
ok, thanks
Old Feb 18, 2001 | 05:25 AM
AdrenalinFreak's Avatar
Assuming that the gas is inside the airbox, then it is from the floats opening up and flooding your intake with fuel. Ocassionally my friends warrior has this problem as does my banshee. It is a big deal (somebody said its wasnt) because it cleans the oil off of your airfilter. Which allows dirt into your intake. If you see fuel in your airbox it is a good idea to re-oil or change your filter as soon as possible.If the fuel is on the outside of the air box, it is from a float bowl vent line that is being flooded.If you can move the line to a different position so that you are not spilling gas all over your bike or yourself as it is a major hazard.
Old Feb 18, 2001 | 11:20 AM
the gas goes down the top of the airbox lid(i made sure to check the inside the first time it happened), then all over the battery, then if i havent tipped it back over yet, it gets all over the rear fenders. id just like to stop it if i could cuz its a pain to clean up
Old Feb 19, 2001 | 10:48 AM
springdrl's Avatar
Giving this more thought, I would think you could store any ATV is position by first turning off the fuel valve at the tank and then draining the float bowl before flipping it up on the roll bar.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
