problem changing gears
Old Jun 8, 2009 | 08:24 PM
calvin120860's Avatar
Default problem changing gears
I have a 2000 sportsman 500; recently changed drive belt. Now it will not come out of gear when idling; I have to shut it off in order to shift from reverse to forward or vice versa. I have turned down the idling as low as it can go without shutting off; still the pressure is on the transmission so that I cannot pull it out of gear. Does the shifter need adjustment? What's going on? I'd appreciate any help I can get.
Thanks.
Old Jun 9, 2009 | 08:00 AM
switzomatic's Avatar
Default Gears
Sounds like a clutch issue.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
blaze_master
May 26, 2015 11:18 AM
