Bad pick up coil cause revving problems?
I posted on here a while back about my 01 Warrior not wanting to rev up and i thought i found the problem, but after fixing alot of things its still acting up. Using a manual i found online, i believe my pickup-coil might be bad. I think the manual is for a different year as the the wire colors dont seem to match exactly as in the manual but the resistance is far to high even for whatever coil im testing (measured 550 OHMs while the spec is in the low 300s)
So is it possible this could actually be my problem? My spark also seemed a lil weak but after replacing the battery it got alot beter (not perfect, but an improvement) and it still wont seem to rev up.
im not sure about it causing a problem with revving exactly but when they get tired and causes an inconsistent spark they can cause like little hiccups when you try to give it quick little bursts of throttle in my experience, define not wanting to rev up, im not sure what u mean does it feel like it hits a rev limiter or something and how early in the rpms does it do that, if it is the pickup coil you can get those separate at RM stator or Rickys and there like 30-40 bucks i think.
it just sounds like its hitting a rev limiter. The quad is ride-able and but has absolutely no power. Gets up to maybe 25mph in 6th. Probably going to change it out just so tired of waiting on parts at this point. Owed the thing for nearly a month and have absolutely no trail time with it.
