Sportsman 850 XP Question
Yesterday i was cleaning the quad after riding and got some mud and then i was spraying the back lights and nocited that part of the light had 2 plug things in there and was wondering if those could be removed and use those for the brake lights 2 and i heard those are used for the blinkers????
Yes the LEs have a rear work light incorporated in the tail light assy. But,at least on mine,there is no actual hole for the bulb assy..the LEs come with a different tail light assy..also as far as I can tell the XPs,unlike some older machines, don't come with the wiring on them unless they come from the factory with the rear work lights. You need the LE rear light harness(and obviously the switch) to make it factory.
This is the 2 different tail light assemblies..
REG machines
2411153 Asm., Taillight, LH [Incl. 3, Bulb][AL][AQ][AS][AX]
2411154 Asm., Taillight, RH [Incl. 3, Bulb][AL][AQ][AS][AX]
LE Machines...
2410427 Asm., Light, Tail/Work, LH [Incl. 3, Bulb][AT]
2410428 Asm., Light, Tail/Work, RH [Incl. 3, Bulb][AT]
REG machines
LE Machines...
