Sportsman 850 XP Question
Old Jun 12, 2009 | 10:47 AM
gordster1122's Avatar
Default Sportsman 850 XP Question
Yesterday i was cleaning the quad after riding and got some mud and then i was spraying the back lights and nocited that part of the light had 2 plug things in there and was wondering if those could be removed and use those for the brake lights 2 and i heard those are used for the blinkers????
Old Jun 13, 2009 | 06:31 AM
HIGHOCTANE's Avatar
Not sure I understand your question but it already has brake lights..the other place in the tail light is for rear work lights that they put on the LE version.
Old Jun 13, 2009 | 07:28 AM
yeah thats what i was talking about the other part in the lights so thats for the work lights
Old Jun 13, 2009 | 07:43 AM
ZAKAZIM's Avatar
Check this out
Polaris atv, utility-vehicle parts and accessories, OEM and apparel from Don Wood Polaris, Ohio
Old Jun 13, 2009 | 08:46 AM
HIGHOCTANE's Avatar
Yes the LEs have a rear work light incorporated in the tail light assy. But,at least on mine,there is no actual hole for the bulb assy..the LEs come with a different tail light assy..also as far as I can tell the XPs,unlike some older machines, don't come with the wiring on them unless they come from the factory with the rear work lights. You need the LE rear light harness(and obviously the switch) to make it factory.
Old Jun 13, 2009 | 08:54 AM
HIGHOCTANE's Avatar
This is the 2 different tail light assemblies..
REG machines
2411153 Asm., Taillight, LH [Incl. 3, Bulb][AL][AQ][AS][AX]
2411154 Asm., Taillight, RH [Incl. 3, Bulb][AL][AQ][AS][AX]
LE Machines...
2410427 Asm., Light, Tail/Work, LH [Incl. 3, Bulb][AT]
2410428 Asm., Light, Tail/Work, RH [Incl. 3, Bulb][AT]
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
