what are clutch buttons?
Old Jun 13, 2009 | 07:35 PM
HARLEY_OWNER's Avatar
Default what are clutch buttons?
whats the real name or whatever and how much are they...
also how many do i need... my quad is in the shop and i thought it was the top end but it wasnt... my clutch is knocking and someone said it is the clutch buttons... how many do i need?
Old Jun 13, 2009 | 08:12 PM
6 clutch buttons ride in the spyder of the front clutch. As they wear down and if not replaced quick enough, damage to the areas they slide up and down on can happen,usually grooves are cut into the metal and its the slack from the worn buttons and glide area that makes the noise! Can sound like a rod going out or can sound like a diesel truck! Unless you have the spyder removal tool,best to let the shop do it if the clutch is able to be saved. I have had a few that went a little too far and sometimes the spyder and clutch are too worn to properly repair. Hope buttons are all you need! OPT
Old Jun 13, 2009 | 08:14 PM
yea it was getting bad... my friend can get the tool do this job and knows how... should i do this or leave it in the shop... the guy at the shop said around 300...
Old Jun 13, 2009 | 08:31 PM
They must be planning on replacing more than the buttons for that kind of money!! OR i'm not charging enough myself!
Old Jun 13, 2009 | 08:36 PM
thats the thing.. i think he is gonna rebuild it or somthing...? he haddnt even tore into it yet... but if its just the buttons or even clutch arnt both relitivly cheap?
Old Jun 13, 2009 | 08:38 PM
if mine has ebs .. does it still have buttons?
Old Jun 14, 2009 | 08:35 PM
yep
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
