84 honda 200m wont start
Old Jun 15, 2009 | 10:29 AM
djblade17's Avatar
Default 84 honda 200m wont start
Its a buddies
History, The thing was spitting oil and smoke out of the exhaust
we had to replace the cyclinder it was really beat up the piston and rings
The wiring harness is in bad shape
At first he was not able to get spark
I was able to rewire it so now it has spark
At first it would try to start but back fire on 1 out of 10 turn overs
we thought it was the timing so we adjusted that got the info from the manual and this site
everything is lined up
But now its just nothing no back fire or anything
It is getting gas and it is sparking
any ideas or questions?
Thanks
Last edited by djblade17; Jun 15, 2009 at 11:02 AM. Reason: Timing might not be right on ?
Old Jun 16, 2009 | 09:30 PM
3wheelcrazy's Avatar
go thru the harness piece by piece, only takes one bad connection to ruin your day... check your compression, with the head work make sure compression is what it should be. check the compression release also. dble check the timing to be sure. more than likely its electrical even if you have spark. had a similar issue with a 4 wheeler one time.
Old Jun 17, 2009 | 08:08 AM
pcollins's Avatar
timing is the thing i'd double check. my 70 had the major backfire issue out the carb. adjusted the points timing and it ran perfect.
Old Jun 17, 2009 | 09:03 AM
djblade17's Avatar
Hey guys thanks for the info
It seems the compression was the issue.... He replaced the cylinder with his old one it fired right up needed to adjust the timing a little bit but we were out on the trails for ours yesterday....
He actually has the engine on a quad frame he bought it like that for 100 bucks
It runs pretty good for the most part
neilbedwell
Nov 10, 2018 11:02 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
