HELP ANSWER QUICKLY NEED ANSWER 26" Mud Bugs on 05 Polaris Sportsman
I just bought (front)26x10x12 and 26x12x12(Rear) Maxxis Mud Bug tires and i want to know if they will fit a stock 05 Polaris Sportsman 500 Ho 4x4 with no rubbing in front or rear? Anyone else had this problem? Thanks alot , Cody
I don't know on an '05...
However, they will NOT fit a '96 without spacers. At least, they wouldn't fit mine. You could mount them backwards on the rims and they'd fit, but you'd have to move your valve stems.
-J
-J
They will probably rub on the tie rod ends without spacers. You can flip them around and realign it, and then they will clear. Also depending on the side lug on the tire they may rub slightly on the spring. Hope this helps!
bzdok1234
30
Feb 23, 2016 01:55 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
