Help with the hilliard clutch system
Old Jun 24, 2009 | 03:33 PM
dvxwarriorkq's Avatar
Default Help with the hilliard clutch system
I have a Polaris 500 scrammy, model 2000. Lost an axle and replaced with aftermarket. Something wasn't seated right and after 1 ride noticed slop in the hub. Removed the assy and must have not seated components correctly-had damaged arm plate and clutch back. Heres the prob-I tried switching all components from good side-to the new axle side and no engagement. I have a good pull @ the coil. This just doesn.t make sense. I cleaned up all roughness on coil facing and cleaned all aluminum shavings out of hub. The old assy will not work on the good side, but no big surprise there. I was able to clean up the damaged parts ok, Make the tangs stick out again on the old arm plate. This is driving me crazy. All components on the new axle side are good-what am I missing? Any help from yall would be appreciated.
Old Jun 24, 2009 | 06:18 PM
Replace the 3 tab armature plate first,check the hilliard bearings,cage (especially around the tab cutout area) and spring . If hilliard assy damaged,then replace. Torque hub nut to 12 foot pounds! FORGOT to say check the strut area where the armature plate rests for damage at face of coil and strut itself.If strut is ground down and rough,then awd wont work! I've replaced several because of this. Hope its just minor OPT
Old Jun 24, 2009 | 07:53 PM
Default 3wd scrammy
Many thanks for the good info-I'll start with the plate and go from there. My coil facing was rough-I smoothed it down with some emery cloth-from your reply could you clarify IF its possible to clean up this facing without replacing it? There are no scratches in it deep enough to catch a fingernail in. Most probably damaged cage/roller assy enough to need to replace-planning on that as well.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
