?? 1996 magnum 425
Old Jun 25, 2009 | 09:28 PM
wbs_@hotmail.com's Avatar
Default ?? 1996 magnum 425
Im looking at a 96 magnum 4x4 never had a polaris before. The owner says that it runs great about a half hour then it starts to run rough and backfires
also the exhaust gets very hot in fact it melted the side panel. any ideas is this one problem or two any one ever run into any thing like this. Also does this machine have points in it?
Bill "Thanks for all your help"
Old Jun 25, 2009 | 09:54 PM
lang827's Avatar
Exhaust melting the plastic is very common on that model. I put heat tape on the plastic and put a block between the plastic and the frame to push it out from the pipe another 1/2" and that fixed the problem. No points.
nkkiegem123's Avatar
yes i also heard that but i didn't find it in this website about 2months ago. I'll try to find it somewhere else.
Old Jun 26, 2009 | 12:37 AM
CaptainQuint's Avatar
Mine runs pretty hot especially in the summer. Your leg gets pretty warm.
My main gripe with it is that it is chain drive. You're constantly having to screw around with the chain. You have to keep a close eye on the tension or you end up throwing it in a mud hole or something. That and while the rear chain is fairly simple to adjust the rest are a pain to access.
Other than that it's been a solid machine for me and I work mine to death.
Old Jun 26, 2009 | 01:16 AM
goodblasson's Avatar
Do yourself a favor and run away as fast as you can. It will develop an incurable disease. I have had the worst experience with the 425 Magnum, do some searches and you will find out for yourself. On the other hand, my 250 Trailblazer has been the best quad I have ever owned and would not trade it for any other, its a 1996 and never had any trouble to date.
Old Jun 26, 2009 | 04:33 PM
hoytultratec's Avatar
stay away from it! though a decent machine they take a ton of mantinance to keep all the chains tight. plus the thing has problems you are not sure what they are. I bought mine and it had so much wrong with it ive rebuilt the whole darn thing.
Old Dec 6, 2017 | 12:38 AM
Andrew James Gardner I's Avatar
Looking for parts for my magnum 425. Heat shield, right side plastic cover, and muffler. Any help appreciated!
Old Dec 6, 2017 | 02:27 AM
If no one on the forum can help you check ebay,craigslist,etc. Plus you can google atv salve yards. Several listed.http://www.stevescyclesalvage.info/U...Tifton-GA.htmlhttps://www.cyclesrus.net/
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
chewy78
Sep 8, 2015 10:37 AM
