98 Xplorer tranny in 98 Scrambler???
Old Jun 28, 2009 | 06:15 PM
IamBIGGUN's Avatar
Default 98 Xplorer tranny in 98 Scrambler???
Is a tranny from a 98 Xplorer 400 4x4 a direct bolt in to a 98 Scrambler 400?
My scrambler 400 is a shaft drive front end and I'm not sure if the Xplorer is or not.
Does anyone who has done the low range swap know?
Thanks,
Kevin
Old Jun 29, 2009 | 07:46 PM
IamBIGGUN's Avatar
Anyone??????
Old Jun 30, 2009 | 12:23 AM
94harley's Avatar
Thanks,
Kevin
The two trans you speak of are different. I have done a low range swap on an older machine and this thread tells a little bit about my experience.
http://forums.atvconnection.com/pola...nsmission.html
Old Jun 30, 2009 | 01:20 AM
IamBIGGUN's Avatar
Nice write up!
When you say they are different do you mean because of the low gear and shifter mods or that the tranny wont fit even if the linkage is modified?
I know about the shifter problems and I'm willing to deal with that. I just want to get a tranny that will be a direct bolt in for the frame and alignment.
Kevin
Old Jun 30, 2009 | 08:40 AM
94harley's Avatar
Nice write up!
Kevin
They are physically different. All I did was look at the parts list for both. The explorer uses chains for the 4wd, your scrambler uses a driveshaft. So it will not work.
Old Jun 30, 2009 | 10:33 AM
IamBIGGUN's Avatar
Okay. Thanks.
I wasn't sure if it was chain or shaft. Did any of the xplorers come with shaft drive?
Kevin
Old Jul 22, 2009 | 12:49 AM
mrtwostroke's Avatar
xplorers weren't shaft drive unitl 2000
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
rockinkgin
Sep 25, 2015 01:52 PM
