Oil injection bypass
I want to bypass my oil injection what do I mix my xplorer 300 at ? I also gave her alittle body mod...I put new pro taper bars on and removed the dummy lights, after doing so my headlights brake lights and fan didn't work. I wired the fan direct on a toggle, Why would those dummy lights effect everything? do they have to be there to complete the circuits? I went riding yesterday and she started running rough, She finally quit thats when I realized the fan wasn't working. I let cool and got her home, wired the fan, went for another ride...quit again, seemed to be a fuel issue dirt in tank wasn't getting fuel so I put it reserve got her home...cleaned the tank put fresh gas in went around the block and she quit again half way can't get her started???????????? what now???
Dont know how you wired things up,but sounds like a ground problem OR you are triggering the thermal fuse. Oil line goes directly into carb on left side,if has oil in line I would leave alone as pumps are pretty dependable,BUT if you have to disconnect make sure the carb inlet is blocked off.
incpecting the oil pumps ever so often insures you wont have a failure Ive had 2 2 strokes and never had a engine burn up but i did have one pump go to crap but stuck open I was wondering why it smoked so bad and i was going through so much oil. now I check it once a year and make sure the spring looks good and its staying clean inside. I hate premixing
jrooker6
Apr 23, 2016 07:36 PM
