Dead Timberwolf?
Old Jun 29, 2009 | 11:30 AM
TuckerR1980's Avatar
Default Dead Timberwolf?
I tend to run my 92 timberwolf flat out so I knew this day was coming at some point. The other day while out on a trail I was doing maybe 20 mph when got a rattle all of a sudden i was able to throttle for a a couple of seconds then it had stalled out. It does crank over and has compression so i know i didnt blow the piston rod but I was wondering if this possibly sounded like the timing chain at all. Oh and while turning the engine over there is still a knock in the bottom end it sounds like. Thanks in advance for any help.
On a second note I was wondering if anyone knew if any of the other yamaha small engines would bolt right in like some of the 350s.
Old Jun 29, 2009 | 06:52 PM
wheily's Avatar
id say it was timing chian i had a kawi do the same thing as for engines that will fit not sure ...welll any will fit if you have time and efert
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
