Xpedition 425 Crank overflowing with gas
Old Jun 29, 2009 | 06:50 PM
northshoremb's Avatar
Unhappy Xpedition 425 Crank overflowing with gas
I just took the dipstick out of the crank and it started to overflow all over the ground. Surprised me cause bike hasnt been run in a month and the oil sure looked tin. Dipped my finger in to find out that it is gas and have no idea how it got in there and is it a serious problem???
What I want to know is how did it get in there and how do I stop it from happening again???
Dont wanna end up 60 miles back in bush and engine seizes. I am very mechanical and have rebuilt many 2 stroke bikes and snowmachines in my racing career, but when it comes to 4 Strokes I have never even tried to take one apart.
Also what should the compression be on this 4 stroke and do I test it the same as my 2 strokes??
Old Jun 29, 2009 | 06:55 PM
midcity mudder's Avatar
Hi man, most like the needle and seat inside your carb is worn out or the floats inside the carb are stuck wide open causing gas to leak into your engine. Let me know.
Old Jun 29, 2009 | 06:57 PM
OK I will check it out
But did I do any damage with all that gas in there? And do I just drain it and fill it back to specs with regular oil??
Old Jun 29, 2009 | 07:04 PM
Yup! but first you need to remove the carb and repair this issue it could just sometimes be a piece of dirt that got stuck. But if the carb has never been serviced it's most likely needle and seat. No you didn't harm the engine but yes I would definitly drain all the oil out and let sit for a little while to evaporate the remaining fuel or perform a couple oil changes and also replace the filter. Let me know how you made out Happy Trails.
Old Jun 29, 2009 | 07:09 PM
Where about's in ontario are you from anyway
Old Jul 20, 2009 | 12:57 PM
Angry
HERES AN UPDATE!!!!!!!!!!!!!!!!!!
I took the carb apart and fully cleaned and adjusted it as well as put in new needle and seat as suggested. Changed oil fiter and drain crankcase and filled her up. Well I went for a 30 mile ride to camp checked oil and crank was fine, however when we got back to the truck after 30 miles back I checked crank again and bingo full of gas again.
What the heck is causing this?? I just spent $50 in Oil $15 filter and $50 for needle and seat and that didnt fix it. I spent $115 for nothing and now need to change oil again and fiter.
On the ride it did this 3 times (while driving through a slow spot it bogged down and stop, then another time it bogged down while driving in 4th)
Old Jul 20, 2009 | 02:49 PM
Kerbbirds's Avatar
You must have sand or dirt in the tank causing the needle and seat to stick, take the tank off and dump it and rinse it, pour it through a white rag and you should be able to see the dirt.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
