300ex question
Old Jun 30, 2009 | 06:56 PM
blacklabel21's Avatar
Default 300ex question
Well i have a 1996 honda 300ex.My question is i want to lift my 300ex.I do alot of trail riding and playing in the mud with it.I cant find a lift kit for it.So i was thinking i would just get wheel spacers and bigger rear tires and front tires.My question is how big of tires could i get the the rear and front tires,Without damaging anything else.
Old Jun 30, 2009 | 07:39 PM
sprayedgt's Avatar
You can go pretty big on the rear tires. I have a friend that has 25" rears on his 300EX. The problem is, the bottom end power will absolutely be horrible with taller tires. His is like a snail on the bottom end.
Old Jun 30, 2009 | 08:19 PM
budedm's Avatar
If the bottom end suffers, you can change the front or rear sprocket. OEM is 13/38. You can go 12/38 or 12/39.
Old Jun 30, 2009 | 09:30 PM
Tim Smith's Avatar
If you get stronger springs so the suspension is at max droop all the time you could probably get away with just about anything on the back that will fit under the fender. Just measure the distance between the axle and the closest part of the fender at full compression (buddy will help here).
The fronts are going to be dictated by the clearance on the foot peg frame area I think.
22" is the stock height so a 25" would be an increase of 13%. So...13/38 gearing is a ratio of 2.92:1. Increase that to 3.29:1 to get the 13% increase. That is right between what budedm suggested.
bigred20653
Oct 2, 2015 10:05 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
