Honda recon issue
Old Jul 1, 2009 | 12:14 AM
wastedpineapple's Avatar
Default Honda recon issue
so recently let my brother took my atv out and now when i get it back it wont go up any sort of incline. It will run through all the gears just fine on flat land but when i try to go up a 4 foot hill it stalls in the middle it sounds like its bogging out real bad. I looked at the air filter there was nothing in the box and the filter is clean, the gas is fresh so there is no water in it, i changed the plug so its not that, now im lost. its not smoking but it sounds like it back fires when it slows down or when i shift down. my brother said he had it in a creek and was doing donuts on a slate bottom, from what this sounds like is the top end blown on my atv or does anyone have any idea on how to fix this issue.
Old Jul 3, 2009 | 02:23 PM
Dillpick351's Avatar
Default well..
it sounds like a gas problem since its just when your going uphill. have you tryed just flooring it uphill
Old Jul 4, 2009 | 10:53 AM
The Kid's Avatar
check the float height in the carb
Old Jul 4, 2009 | 11:01 AM
The Toolman's Avatar
More than likely a few beads of water in the botom of the carb bowl. Drain it an squirt a little carb cleaner thru the drain hole under the screw.
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
MNatv89
Jul 7, 2015 11:36 AM
