clicking transmission in 2005 kodiak
Old Jul 2, 2009 | 08:13 PM
takoda's Avatar
Default clicking transmission in 2005 kodiak
I recently bought a used kodiak. It only had 124 miles on it, about twice that now. When I first start it up, sometimes it clicks (like fan blades on a box fan hitting something). If I put it back in park and rock it a bit, it will go into reverse but then often doesn't want to come out of reverse. I have to back around for a minute or two and then everything is fine. Is this normal? Am I just not letting it warm up enough or do I have a potential problem I should get looked at before my 60-day warranty expires?
Old Jul 3, 2009 | 12:16 AM
Yamaha_4_Life's Avatar
That is definitely not normal and you should take it in for sure. I have an 04 450 Kodiak and I don't experience such symptoms.
You should be able to start it if cold with half choke and let it run for 40 seconds or so then it just idles until I think it is good to go. And a healthy Kodiak should not be doing that. Putting it into H or L from park it should go when you hit the gas, same with reverse. Hopefully you get it fixed under your warranty, which I am sure you will.
They are great bikes.
Old Jul 5, 2009 | 04:42 PM
yamikodiak07's Avatar
wait dont take it in yet, is it a tick like when you drive tick tick tick, i have that problem, its only an axle the guy i bought it from told me and to make sure i took to dealer, its an axle there's 4 in a independent and 2 in straight, i brook my rear right, it fads aways somtimes but always comes back its the axle slowly breaking, so it will bust soon
Old Jul 5, 2009 | 10:09 PM
Traildad's Avatar
When my wife tries to shift into gear with too high an idle it makes that kind of noise as she shifts it. Is it possible that there is a shifter adjustment that needs to be made. Maybe it is not resting completely in neutral.
Old Jul 6, 2009 | 03:41 AM
Malachi's Avatar
The reverse problem sounds like it could just be a shift shaft(shaft from shifter to side of block) adjustment. You can adjust it by undoing the lock nuts on both ends and rotating the shaft in either direction. Rotate one way to extend the shaft and the other to shorten it. Only do small adjustments like 1/4 turn and test. Mark it first so you can set it back if needed.
If that doesn't work try this.
There's a large bolt near the shift cam on the outside of the block. It's hollow with a heavy spring inside and a ball that sits on the spring. This ball and spring hold the shift cam in gear as you move the shifter. If either the spring or ball are worn out the shifting may not engage or could stay between 2 gears.
The clicking sound your hearing is probably the cam not getting into the gear you need. Undo the bolt to see if all parts are there. You may need a small magnet to get the ball out. Once you've got it out look inside with a flashlight as you shift the shifter. You should be able to see the dimples on the shift cam rotate by. These are what the ball falls into and holds it in the corect gear. Make sure you can see a dimple for each gear. This step may also help with the shift shaft adjustment.
Old Jul 7, 2009 | 09:17 AM
ajust the idle speed,
salixair
Nov 3, 2015 08:25 AM
YankeeRebel
Oct 6, 2015 06:44 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Brandon400
Sep 5, 2015 08:44 PM
