fourtrax problem
Old Jul 4, 2009 | 11:59 AM
dh1's Avatar
dh1
Default fourtrax problem
I have a 2002 350 fourtrax and it keeps draining the battery. Anyone have an idea as to why? Battery is good and bike is in great shape with only 1500 kms on it. It runs great but if I don't use it for about a week the battery is dead! Thanks
Old Jul 4, 2009 | 02:53 PM
JeffinTD's Avatar
Do you have a multi-meter? If not, buy one (they are cheap these days).
With the key off, take the negative battery cable off and take an amp meter reading between the cable and battery. A few mili-amps would be normal, but start on a higher range so as not to peg out the meter if there is a large drain.
If there is excessive key off drain, I'd look first at aftermarket accessories (heated grips or whatever), and next try unhooking the regulator/rectifier to see if that makes the drain go away.
You may also want to see what the charging system is doing. Take a volt meter reading from the battery with machine off, and with it running and reved up a bit.
Also, it takes an ATV's charging system a long time to bring a dead battery back to full charge... How are you recharging it when you found it dead?
Old Jul 4, 2009 | 03:38 PM
dh1's Avatar
dh1
thanks. I've been throwing it on the battery charger.
Old Jul 4, 2009 | 08:00 PM
JeffinTD's Avatar
Post back the results when you check for key off drain.
Even if the battery is relatively new, it still could be the problem.
Also, welcome to the forum.
Old Jul 4, 2009 | 08:52 PM
dh1's Avatar
dh1
Thanks. I had a load test done on the battery and they said it was good.
Old Jul 5, 2009 | 07:22 AM
JeffinTD's Avatar
Sometimes they can load test good, but have an internal drain...
Anyway, a quick test with a meter will tell you if the drain is the quad.
Regulator/rectifiers have been known to go bad and result in a key off drain. Usually Hondas are wired so that the main things connected to battery voltage all the time are the ignition switch, and the regulator, and the key switch rarely fails.
Old Jul 5, 2009 | 09:25 AM
dh1's Avatar
dh1
thanks. I'll have to get a tester.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
