backfiring
Old Jul 7, 2009 | 11:15 AM
snowpacker's Avatar
Default backfiring
2006 sportsmen 700 efi backfiring after a wot jaunt I recently cleaned k&n filter and refoamed ........at first I thought it was just the oil from the foam getting sucked in but that was 2 rides ago.....probably 60 miles on after I cleaned filter. I didn't put the polaris pre filter on over k&n filter......got about 1000 miles on machine with K&n filter with no previous backfiring issues.....
maybe bad gas?
water in fuel.....I'll have to try some dry gas...maybe?
Old Jul 7, 2009 | 01:16 PM
Big600twin's Avatar
Many postings on backfiring....Could be a pinched vent tube, bad gas, maybe air box not installed just right....Could be something got in fuel line?? Fuel filter??
Old Jul 7, 2009 | 08:32 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Check the tube that is about 5/8" in diameter under the airbox just in front, see if you have a kink or cut hose. I had a cut in mine, back fired all the time, replaced hose and no more
Old Jul 8, 2009 | 12:05 AM
noooooo's Avatar
My 09 850 XP was backfiring. The dealer adjusted the throttle cable (throttle position sensor) and it seems to have cured it.
Old Jul 8, 2009 | 04:27 PM
patrolman800's Avatar
Been there done that! those new TPS are very sensative.
Old Jul 8, 2009 | 07:57 PM
eggenz7's Avatar
how about the valves? when was the last time they were adjusted?
Old Jul 9, 2009 | 06:10 AM
snowpacker's Avatar
thanks
I'll have to go home and check vent line...sounds like thats were everyody is heading me
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
