'88 trx300 firing problem
Old Jul 9, 2009 | 07:35 PM
muddbone's Avatar
Default '88 trx300 firing problem
I'm getting fire from the stator to the cdi. Nothing from the coil. Coil is good. Is my cdi bad? It sparked very lightly a couple of times and that's it. I used a charger to jump the atv. Did i burn the cdi? Thanks in advance.
Old Jul 10, 2009 | 06:40 AM
fourtraxhonda300's Avatar
If you used a car battery or high output charger to start it, it usually burns up a few things in the wireing, We did ours like that, sadly.. But our CDI box, and major electrical components are good. Its most likely nothing major.. Check EVERY wire on your fourwheeler though. I cant remember what burned up on ours.. I'll check through my parts lists of what I bought, and see. I hope you get the old 300 running!
Old Jul 10, 2009 | 05:26 PM
muddbone's Avatar
Thank you for the info. I would greatly appreciate it if you could give me an idea of what you had to replace. I have traced wires and checked fuses and can't find anything obvious. Again, thanks for your time.
Old Jul 17, 2009 | 04:54 PM
muddbone's Avatar
I'm getting a single spark when i begin the kick start cycle. If i kick hard, i get no spark. If i just start the kick, i'll get one spark everytime. Any suggestions? Also, i'm not looking for a bunch of free info, but does anyone have the values(ohms) of the cdi box? I have a manual on the way, just not here yet. Any help is appreciated.
Old Jul 18, 2009 | 03:12 PM
HondaMechanic's Avatar
Here are the ignition tests ..
Old Jul 18, 2009 | 05:22 PM
muddbone's Avatar
HondaMechanic, Thank you kindly for the information. I sincerely appreciate your time and trouble. Thanks again.
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 17, 2015 08:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
