yamaha champ 100 wont start
Old Jul 10, 2009 | 09:23 PM
slimhappy02's Avatar
Default yamaha champ 100 wont start
i have a 87 champ that i replaced a bent intake valve in and now i got good spark compression and even using starting fluid it wont start please help
Old Jul 10, 2009 | 10:26 PM
Terrellster's Avatar
That one is similar to one of mine,... A slightly slow starter will not turn it fast enough to git 'er runnin'. Use some jumper cables and do a one time start and see if that helps.
If not, it may be time to check the valves again. They're kinda hard to set while the engine is installed, but it can be done. I suspect you already set them on the new valve install, but check them once more and varify timing if the jump start won't do it.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
neilbedwell
Nov 10, 2018 11:02 AM
cornermike
Jun 3, 2015 07:27 AM
1000gade
May 27, 2015 12:37 PM
250Man400
Jun 28, 2000 08:57 PM
