Honda Big Red 200 es Spark Problem
Old Jul 11, 2009 | 03:27 PM
Warby's Avatar
Default Honda Big Red 200 es Spark Problem
My teenage son recently inherited a Big Red from his great grand father, This thing is mint. It ran when we first brought it home but has since stopped. We took the coil off and cleaned the terminals but no luck. One interesting note though. If you remove the coil and touch the black and yellow wire that plugs into the coil while pulling it over you will get a shock. Although if you pluge the coil back in and hold the end of the coil wire no shock. Does this mean that the coil is shot? Also why are we getting a shock with the coil removed? Is this current coming from the staor coil. Thx in advance
Cory
Old Jul 13, 2009 | 02:28 PM
1fastford's Avatar
how many volts are going into the coil when you pull it over?
i have the same problem.ive got a used coil off of ebay and same problem.? i dont know if they sent me a bad coil but im allso confused
Old Jul 16, 2009 | 05:37 AM
HondaMechanic's Avatar
Here are the ignition tests ..
Old Jul 17, 2009 | 08:18 AM
Warby's Avatar
Default Re: Big Red No Spark.
O.K. I took the Ignition coil in to be tested and was told it is dine. Upon further inspection the shok were are receiving from the black and yellow wire going into the ignition coil is slight and intermittent. Where the shock is strongest is on the black wire before it goes into the little black plug in box attached to the cross bar under the gas tank. Any help would be great, thx ahead of time. Warby
Old Jul 19, 2009 | 08:47 AM
Warby's Avatar
Default Bg Red Spark issue
O.K. I took the Ignition coil in to be tested and was told it is fine. Upon further inspection the shock we're receiving from the black and yellow wire going into the ignition coil is slight and intermittent. Where the shock is strongest is on the black wire before it goes into the little black plug in box attached to the cross bar under the gas tank. Any help would be great, thx ahead of time. Warby
njrider64
Jul 4, 2017 01:40 AM
Land_shark1
Jul 10, 2015 12:53 AM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
