Still getting water in rear end
Old Jul 14, 2009 | 05:03 PM
polymite's Avatar
Default Still getting water in rear end
Working on a 97 300 trx. The bike has been fully snorkeled, vented etc.
Replaced the rear brakes, seals and berings on the right side. Yes applyed grease to seals.
Problem is we are still getting water in the rear end gear side and just a touch of rear end grease in the brake side.
I have not replaced the seals on the left side of the rear end, this seems to be the logical problem. If anyone has a diagram of the left side of the rear end please post it.
Thanks in advance.
Old Jul 16, 2009 | 04:03 PM
polymite's Avatar
Come on guys chime in anytime now.
Hondamechanic, reconrancher come on guys.
Thanks in advance.
Al
Old Jul 16, 2009 | 04:17 PM
wheily's Avatar
sounds like maybe you have some play in bearings.. witch would let axle move enough to push seal open. im not familliar with ur machine but on my old 4x4 we would put a exstra seal in backwords as they only stop fluids in one direction. maybe you could try that
Old Jul 23, 2009 | 09:25 PM
polymite's Avatar
thanks for the input but I was really wanting some of the great honda manual pictures that give detailed information on the left side seals...
Thanks again.
Old Jul 24, 2009 | 07:43 AM
action450s's Avatar
try ronniesmailorder, they have online microfiche that helps alot. if your bearing is bad it will cause the seal to leak. If the surface of teh axle the seal turns in is rough, it will leak (I had to polish my hub and order a smaller inner diameter seal from a bearing supply store once). also if your rear axle is bent it will cause the seal to leak.
Did you extend teh vent lines? Also check for holes or tears in the vent line.
STLyamwar
Jul 25, 2020 04:44 AM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
