replacing starter on 90cc sunl
Old Jul 15, 2009 | 04:23 PM
sunl90cc's Avatar
Default replacing starter on 90cc sunl
Hi-
I need to replace a starter on one of my 90cc Sunl's.
it's a top mount starter.
the end of a new starter has as sprocket that goes to the chain. however the previous owner left that sprocket from the starter on the engine.
Do I take the cap off the left side of the motor to get access to the starter sprocket and lower sprocket that i'm assuming is attached to the crank? Are there pieces that will fall out when I remove that cover?
How do I release tension on the chain to be able to remove the starter sprocket?
Thanks for any info.
Old Jul 16, 2009 | 01:31 PM
spliffy's Avatar
Just take off the left side engine cover & the stator will come off with it & you will be able access to the chain & the sprockets. There is 2 small nylon black chain tensioners in there on both sides of the chain, remove them both & it will the loosen the chain to be able to fit around the new starter & then put the tensioners back in & put the cover back on.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
ghost civic
Jan 15, 2020 07:43 AM
Ramman1
Jun 16, 2016 09:07 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
