Bent shift fork?
Old Feb 19, 2001 | 01:47 PM
warrior3443's Avatar
How can you tell if you have one? Can you tell without tearing apart the motor?
Old Feb 19, 2001 | 09:25 PM
Does anybody know?
Old Feb 19, 2001 | 10:21 PM
AdrenalinFreak's Avatar
The only time I have ever seen a bent shift fork, was on my friends warrior and he had a bunch of other stuff wrong with his bike. The bike didnt want to move in 3rd or 4th gear (he did end up having 2 shift forks bent, dont remember if they were for that gear though) and when he shifted into those gears it shifted different. The shift kinda jammed a bit before it should have went into gear, and you had to hit the shift hard to make it go into gear. As I said though, he had several other problems with his bike at the time and they could have been the cause of the problems.The only way to actually tell if a fork is bent, to the best of my knowledge, is to split the case and look. It might be a good idea to look anyways and put some new bearings in it while its apart.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
meddy0388
Sep 9, 2015 06:41 AM
