what minimum size air compressor is needed to work on an atv?
Old Jul 19, 2009 | 10:07 PM
dsmith222's Avatar
Default what minimum size air compressor is needed to work on an atv?
Hello, I am looking into purchasing an aircompressor so I can use an impact wrench to get some stubborn bolts off of my quad. I am not going to be running tools from it for an extended period of time, just a brief burst for an impact wrench. What is the minimum size, in gallons and psi that I need? Thanks
Old Jul 20, 2009 | 07:23 AM
budedm's Avatar
Lowes or HD should have a chart for sizing a compressor to your needs.
Old Jul 20, 2009 | 09:39 AM
JeffinTD's Avatar
The typical 5 gal job would be a bit of overkill, but would let you rotate your car tires, and would keep up better blowing things off. It will also work better than a smaller one for seating the bead on tires and stuff like that.
Though a lot cheaper, the direct drive oil-less ones are loud and basically disposable. For the occasional use home owner/home mechanic they will last a lot of years.
If all you want is an impact gun and you have no other use for the compressor, you might consider an electric impact gun.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
cva81
Club News and Events
May 25, 2015 08:23 PM
undecided
Sep 7, 1999 05:42 PM
