Where the Y-Pipe meets?????
Old Jul 21, 2009 | 06:25 AM
Ragelite's Avatar
Default Where the Y-Pipe meets?????
Ok so about a month after I got my bike I knew I had an exhaust leak form the front and I could hear and see it coming form the where the manifold meets the pipe. So I change the Donut gasket and it seemed fine. I was out last night and could hear a bit of a leak so I looked down and I can see that gasket spin when I hit the throttle hard. Its like the springs aren't pulling it tight enough (Just bought the 2 springs) so could it be the rubber mount thats a little ways way back? I change it as well and right now I have it so its pushing the pipe pretty hard up...any thoughts?
Thanks.
Old Jul 21, 2009 | 07:43 AM
larrygan's Avatar
Are you talking about xp550 or xp850
Old Jul 21, 2009 | 08:02 AM
SPORTSMAN70003's Avatar
Mine was leaking and I doubled up on the springs (2 on each side). You might need to bend the tabs where the springs hooks on to put more tension on it.
Old Jul 21, 2009 | 08:49 AM
Ragelite's Avatar
Sportsman 600 twin. I really dont think I should be able to see it spin, just doesn't look right, but its the first bike Ive owned so I though this is the best place to ask. Will the tabs bend easy or should I heat them? And Im guessing bend them back eh?? Ill try that tonight and then if that doesn't work Ill get 2 more springs. What about where the pipe turns and heads back? The rubber mount thats there, should it just be snug enough so the pipe doesn't jump around?
Thanks guys.
Johnny Mac
Aug 15, 2019 03:13 PM
Mar 22, 2016 09:55 AM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
fredrikrosen
Sep 28, 2015 09:58 PM
greg86hd
Sep 16, 2015 12:32 AM
