84 Honda 200S won't stay running
Old Jul 25, 2009 | 12:52 PM
santbaker's Avatar
Default 84 Honda 200S won't stay running
I've had this since it was new,but haven't started it in a few YEARS. It has fresh gas and oil, will start and idle with the choke on, but when I turn the choke off, it dies. Sprayed carb cleaner into carb, will partially run with choke on. What's next?
Old Jul 25, 2009 | 07:26 PM
swampyjunior's Avatar
Remove the carb and clean the fuel deposits from it sitting for a few years. Your choke is more than likely an enriching choke so it give it more fuel and less air. As soon as you turn the choke off the rest of the jets are plugged and it does not get enough fuel to stay running and dies.
SJ
Old Jul 26, 2009 | 03:37 PM
santbaker's Avatar
Thanks, I'll try that tonight.
Old Jul 29, 2009 | 09:37 PM
santbaker's Avatar
Default Thank you
I took the carb apart, cleaned the fuel lines. Carb is still out of adjustment some, but better. Will work on adjustments this weekend. Thanks again for your help.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Land_shark1
Jul 10, 2015 12:53 AM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
lovinhonda
Jan 25, 2000 09:17 PM
