2007 Sportsman 500 EFI
I have read some other posts and would appreciate it if you refrain from telling me my "EFI" is junk. I am just looking for some knowledge. If you don't know, you don't have to respond.
I have a 2007 Sportsman 500 EFI and am having problems with it not running right at mid throttle. It idles fine and it will pick the front wheels off the ground when I mash it, but I can not just give it partial throttle. I was told that it may be TPS and was told that it can be tested with a meter, but I don't have a service manual. Does anyone know the prosedure for testing the TPS on my bike?
I appreciate any response that addresses this issue.
PaHunterGuy
PaHunterGuy
Just got off the bike again. It ran fine for 20 minuets around the farm. I stopped to talk to my neighbor and after sitting for 5 min, it started acting up again. The bike only has 56 hrs on it, and the air filter is clean. I may pull the plug next (once the rain passes) and check it. I believe I have an extra one so I'll replace it first. If that doesn't work, I think that it's something electrical. I'm wondering if it's a heat sensor or something. I hate to start throwing parts at it though. This is driving me nuts
Thanks for the input.
PaHunterGuy
PaHunterGuy
i dont want to hear or see any hardcore bashing going on. a little friendly down playing is one thing but lets not be running another members ride down. check your IM box for a message.
Thanks for all the help!! The problem was the MAP sensor cable. The cable protector has wore through the two outer wires. While trouble shooting, I unplugged it and plugged it back in and since messing with it, the computer now throws the code. I am going to get a new cable and replace it first, if that doesn't fix it, I'll order the sensor.
Again, thanks for all the help!!
PaHunterGuy
PaHunterGuy
