2007 Sportsman 500 EFI
Old Jul 25, 2009 | 03:01 PM
pahunterguy's Avatar
Exclamation 2007 Sportsman 500 EFI
I have read some other posts and would appreciate it if you refrain from telling me my "EFI" is junk. I am just looking for some knowledge. If you don't know, you don't have to respond.
I have a 2007 Sportsman 500 EFI and am having problems with it not running right at mid throttle. It idles fine and it will pick the front wheels off the ground when I mash it, but I can not just give it partial throttle. I was told that it may be TPS and was told that it can be tested with a meter, but I don't have a service manual. Does anyone know the prosedure for testing the TPS on my bike?
I appreciate any response that addresses this issue.
PaHunterGuy
Old Jul 25, 2009 | 03:55 PM
RickCJ7's Avatar
EFI junk? better than any obsolete carb.
The TPS should throw a code if bad. Check the air filter and plug.
Old Jul 25, 2009 | 05:25 PM
Just got off the bike again. It ran fine for 20 minuets around the farm. I stopped to talk to my neighbor and after sitting for 5 min, it started acting up again. The bike only has 56 hrs on it, and the air filter is clean. I may pull the plug next (once the rain passes) and check it. I believe I have an extra one so I'll replace it first. If that doesn't work, I think that it's something electrical. I'm wondering if it's a heat sensor or something. I hate to start throwing parts at it though. This is driving me nuts
Thanks for the input.
PaHunterGuy
Old Jul 25, 2009 | 05:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i dont want to hear or see any hardcore bashing going on. a little friendly down playing is one thing but lets not be running another members ride down. check your IM box for a message.
Old Jul 25, 2009 | 09:14 PM
700 sportsman's Avatar
I have the 08 500 manual, that is basically the same, If you PM me your email, I'll send you, it tells you how to pull the codes, and will help trouble shoot it
Old Jul 25, 2009 | 09:45 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Was there a re-flash for these or was that just for the bigger bore Quads?
.......Caper.........
Old Jul 27, 2009 | 06:43 PM
Thanks for all the help!! The problem was the MAP sensor cable. The cable protector has wore through the two outer wires. While trouble shooting, I unplugged it and plugged it back in and since messing with it, the computer now throws the code. I am going to get a new cable and replace it first, if that doesn't fix it, I'll order the sensor.
Again, thanks for all the help!!
PaHunterGuy
Old Jul 28, 2009 | 05:09 PM
mdj104's Avatar
check your ecm .
Old Jul 28, 2009 | 08:09 PM
I replaced the MAP sensor cable today and all my problems went away. Thanks again for all your help.
PaHunterGuy
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
tropicalnuts
Aug 22, 2015 01:15 PM
readymixer169
Aug 21, 2015 10:05 AM
Sjrpp
Jul 5, 2015 09:04 PM
