05 scrambler
Old Jul 26, 2009 | 05:11 PM
shtopl's Avatar
Default 05 scrambler
Hi, New to the site, really enjoy reading all the posts. I am kinda new to atving always rode dirtbikes and streetbikes but got away from streetbikes because to many idiots on the street. Anyway i have a problem i have a 05 polaris scrambler and the axle bearings are wiped out . I am trying to remove the axle but cant move the sprocket hub. I removed the lock ring on the out side, it moves a little ,it is not seized on, is there another lock ring on the inside . Or is there a better way to remove the axle. Any help would be much appreciated. Thank You
Old Jul 26, 2009 | 07:33 PM
snipe523's Avatar
If you havn't already sign up over at gen3usa.com and get in touch with scramblerXrated. He should be able to answer your question real quick.
Old Jul 26, 2009 | 09:02 PM
PUSHNF8's Avatar
Just went through this with my scrambler. Bikebandit.com has a nice breakdown of the axle assembly. Mines an 04 and fought the entire way. I knew it would and had been spraying it with pb blaster for about a week prior. I believe there is only 1 c-clip on either side of the carrier. The rotor assembly is splined and needed a lot of convincing to come off. I cut the axle nuts (about $6 a piece new)
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
