110cc Loncin Oil Change Question
Old Aug 1, 2009 | 03:14 PM
jacads's Avatar
Default 110cc Loncin Oil Change Question
What weight of oil should I be using and how much does the reservoir hold? I am currently using the factory installed oil that has about 5-6 hours on it but is a bout a year old. Also I don't notice an oil filter on the machine is that correct? How often should the oil be changed on ATVs?
Thanks,
Jacads
Old Aug 2, 2009 | 08:22 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I use Valvoline 10w-40 in all my Chinese and Japanese air cooled 4 strokes...No filter just a screen...I would have changed it when i got it and every 6-12 mos after that depending on use..I dont change my oil unless it looks dirty..Usually about once a year.
Old Aug 2, 2009 | 10:41 AM
jacads's Avatar
Where is the screen located? How much oil does it typically hold?
Thanks
Old Aug 3, 2009 | 08:33 AM
KTM Patrol
Former Chinese POW!
Thanks
I went and looked on my 125 and couldnt find a screen...Not sure where it is now..thought it was like my Honda 50 but its not the same...
They hold a little less than a qt...about 28 ozs..
Old Aug 3, 2009 | 10:09 AM
spliffy's Avatar
The screen is on under the clutch side cover of the ATV. You have to take the right side engine cover off & in the lower right side of the engine you will see the screen, usually you have to take it out with a needle nose pliers as you can only see a side of it... I would never clean it or change it unless your clutch goes out... it is a VERY pourous screen & only stops large particles.
Bratman2
Aug 6, 2022 01:42 AM
coolguy420
Jul 28, 2015 01:54 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
yambam13
Jul 4, 2015 01:49 PM
