Need Help
Old Aug 2, 2009 | 05:11 PM
skeeterflipper's Avatar
Default Need Help
Can anyone guide me on adjusting the valves on a ,08 500 sportsman EFI?
Old Aug 2, 2009 | 05:44 PM
Polarat's Avatar
IMO, a service manual is priceless. I've done an X2 and it was easy because there is about 7" more elbow room. I haven't done my HO yet. Remove the plug (looks like a bolt) on the recoil cover. Pull recoil slowly to line up mark on flywheel. That is Top Dead Center. Remove rocker cover (the hardest part in my opinion, needed to hit it pretty good with hammer handle to get it loose.) Check valve clearance with .008 feeler gage. If not correct, loosen lock nut and adjust with screwdriver. Tighten lock nut while holding screw driver in place. Replace rocker cover. Don't tighten too tight, the screws will break. Don't ask.
Old Aug 2, 2009 | 05:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
do you need to know the tolances? you must have aloty of miles on it all ready if its an 08' and needs adjustment.
Old Aug 2, 2009 | 06:02 PM
Thanks for the info. I only have about 70 hours on it,but the valves rattle through the mid range to the top end. is this normal? The dealer said" they some times need adjusting at around the first few maintenance intervals. Any thoughts
Old Aug 2, 2009 | 08:09 PM
700 sportsman's Avatar
Check your other post I put the info there, and I have the service manual if you need it
