tightening drive chain.
Old Aug 3, 2009 | 10:21 AM
dkmcm4's Avatar
Unhappy tightening drive chain.
Hey everyone. I have a 1997 Big Boss 400L with many many hours on it. It seems the first drive chain has loosened some and I need to tighten it up a little. Can someone please advise me on how to do so.
Thanks.
Old Aug 3, 2009 | 02:28 PM
Thanks.
Check center drive chain first,if its loose loosen center adjuster bolts,ecentric turns to rear to tighten center chain,after tightening 5/8" bolts then check front chain,if needs adjustment ,loosen front 5/8' nut under front ecentric under machine there is an opening,then can use a dull punch to slightly tap ecentric towards rear to tighten front chain. Any time the center is adjusted,the front chain will be affected also and usually needs adjusting.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
NewGuy2481
Oct 6, 2015 05:54 AM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
