rear drive poping
Old Aug 9, 2009 | 06:24 PM
marc340's Avatar
Default rear drive poping
XP 850,I know they have a recall for the vent,but iread something about rear drive or rear diff poping,what it is.
Old Aug 9, 2009 | 08:06 PM
JDB20XD's Avatar
mine doing same thing>dealer says its normal but annoying. i heard if you complain to polaris they will replace the axles. they are using different axles now than they started with
Old Aug 9, 2009 | 09:15 PM
700 sportsman's Avatar
The noise you are hearing the the axles clicking, if you take it in they should change them out under warranty (with some possible complaing, but none the less they should do it)
Old Aug 9, 2009 | 09:31 PM
dorenhagen's Avatar
How common is this problem? Has it been resolved in the newer production runs? If so, when?
Old Aug 9, 2009 | 11:05 PM
carlobee's Avatar
i am kind of confused with the problem. what actually happens?
Old Aug 10, 2009 | 05:09 AM
rancher55's Avatar
Polaris knows about this problem and will replace the axles. They received a marginal batch of axles from a supplier after their first run of machine's. They are ok to use like that but annoying because of the popping or clicking noise in the rear.
Have your dealer call Polaris and find out about getting them replaced! You will need your VIN # and date of manufacture to give to Polaris. Good luck!
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
