Sportman Needle and seat
Old Aug 10, 2009 | 03:19 PM
Polaris Sportsman 450's Avatar
Default Sportman Needle and seat
like you guys have been telling me i got the needle and seat replaced and i am still have the same problem. The fuel is still coming back into my air filter and i am getting 13 MPH what should i do next?
Old Aug 10, 2009 | 11:55 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I would check the float next..........Is the fuel shutting off when the carb is full?
If the fuel running into the air-box after shutting the Quad off?
Is the Quad parked on a incline,Hill,tilted trailer..etc.......
Is the tank venting.so it is letting the pressure out?
........Caper........
Old Aug 11, 2009 | 10:47 AM
the dealer replaced the float pin. the air box is not filling up with fuel just the air filter and pre filter are smell like gas and they are oil. it is parked on a flat ground in the garage. how do i check if the tank is venting?
Old Aug 11, 2009 | 12:14 PM
If the tank is not venting the pressure will build up and may be released through the carb....
But if you have no issues with is stalling,.... it is venting.....With a venting problem many riders need to open the gas cap to allow air into the tank, when gas is being used air needs to be allowed to enter the tank .....Caper........
Old Aug 11, 2009 | 01:43 PM
it does not stall it runs great other than getting 13MPH and it coming back into my air filter.
Old Aug 11, 2009 | 11:18 PM
Is it a stock paper air filter?
.....caper......
.....caper......
Old Aug 12, 2009 | 12:18 AM
yes it is stock right now. i was going to put a K&N air filter on it.
Old Aug 12, 2009 | 12:54 AM
carlobee's Avatar
how did it go after this one?
Old Aug 15, 2009 | 12:46 PM
Ok i got some good news last night. it was the main needle that needs replaces and the main jet. it has a 160 jet in it right now but i was told to put a 154 jet in it for it to run the best at where i am at. thanks for all of you help
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
