Transmission Fluid
Old Aug 13, 2009 | 12:41 AM
kellyisu's Avatar
Default Transmission Fluid
What kind of transmission fluid do you use other than the polaris brand?
Automatic Trans
Thanks
Old Aug 13, 2009 | 01:02 AM
kellyisu's Avatar
Also, where do I fill transmission fluid on my 1998 Polaris Xpress 300 automatic 2cycl.
I know, Manual....I have one coming. All I have right now is the owners manual, not enough info.
Thank You
Old Aug 13, 2009 | 06:28 AM
kellyisu's Avatar
Mornin
Old Aug 13, 2009 | 07:37 AM
scootergptx's Avatar
Supersock
Hired Gun!
For no more than it uses, I just went ahead and bought the Polaris bottle. I'm sure there's alternatives out there, but the savings really isn't that much, and I don't have the worry in the back of my mind of "what if I was wrong".
Looking at this diagram, it's part #41.
This is from a 99 model, for some reason they didn't show the 98. But it should still be the same.
Old Aug 13, 2009 | 07:55 AM
TLC's Avatar
TLC
I use Shell synthetic snowmobile chain case fluid. Just because I had it and the internals parts of my sled's chain case are the same as the Polaris tranny. The chain case fliud bottle does not state its weight anywhere on the bottle though.
Old Aug 13, 2009 | 08:05 AM
Supersock
Hired Gun!
I could see that as a viable alternative.
I guess location has a lot to do with choices. Not too many snowmobiles down here in Dallas.
Old Aug 13, 2009 | 08:07 AM
switzomatic's Avatar
Default Tranny
I agree with Scooter. Although it would be nice if Popo offered bulk containers of fluids, especially differential lube, at a somewhat reduced rate. Either way you still don't save much, if any, using other brands. It's probably more of a preference. One of the other benefits of buying your oil and such from the dealer is it gives you some face time with them as a return customer and may help you down the road, especially if you need some tech advice(if you have a good dealer).
Old Aug 13, 2009 | 04:55 PM
kellyisu's Avatar
Is #41 where you check trans fluid level? If so, you don't add there do you?
Old Aug 13, 2009 | 10:22 PM
kellyisu's Avatar
DO I fill the tranny fluid where the dipstick is?
Also, what is the best way to flush out old old tranny fluid after draining?
Old Aug 13, 2009 | 11:04 PM
kellyisu's Avatar
Anyone?
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
