starting problem
Got a 98 trailblazer 250 when i go to start it all it does is click maybe 2-3 times then it starts and will start all day another day same problem.. whats up with that??
If it only does it the firt time I would say the battery is low, after you run it awile it charges up and is good for the day, when it sits it looses some charge, check it with a multi-meter before you start it, should have 12.5 volts.
