starting problem
Old Aug 14, 2009 | 06:46 AM
trail1's Avatar
Default starting problem
Got a 98 trailblazer 250 when i go to start it all it does is click maybe 2-3 times then it starts and will start all day another day same problem.. whats up with that??
Old Aug 14, 2009 | 06:50 AM
rancher55's Avatar
It could be either the starter is going bad or loose connections at the battery or starter.
Old Aug 14, 2009 | 07:00 AM
Kerbbirds's Avatar
If it only does it the firt time I would say the battery is low, after you run it awile it charges up and is good for the day, when it sits it looses some charge, check it with a multi-meter before you start it, should have 12.5 volts.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
