Rear CV boot help
Old Aug 14, 2009 | 03:48 PM
hddoperator's Avatar
Default Rear CV boot help
I've read the sticky here and I'm pretty sure I can replace the rear inside boot (near the tranny), but I'm not sure it needs replaced because I can't find a tear any place. I did however find that is has slipped off of the indentation on the shaft and is slinging grease. Is it possible to take it apart and re-grease everything and re-use the boot and clips if they aren't damaged? Also what would cause it to slip off the indent in the first place? I jumped a few times this weekend but I wouldn't think that would cause the problem. I think the joint will be ok because I caught it pretty fast.....Thoughts please!
Thanks!
Old Aug 14, 2009 | 03:57 PM
UTU's Avatar
UTU
Default yep but
Just make sure the cv jont is clean use cv grease and make sure the clamp is tight and boot is in the groove. Should be aok....
Thanks!
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
DM2015
Sep 7, 2015 10:36 AM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
