2001 300 kitty
Old Aug 15, 2009 | 11:19 AM
eggenz7's Avatar
Default 2001 300 kitty
this is a dumb question im sure but what is the correct starting procedure for this machine? the wiring is a mess and various switches are messed up/broken. im trying to get the machine running before i dump anymore money into it.
keep in mind the starter does not work so im having to pull start it.
is there a park brake that has to be set or a hand/foot brake needs to be pulled in.
i do have to the service manual but have not found anything in there about the starting sequence
Old Aug 17, 2009 | 12:39 AM
swampyjunior's Avatar
Should be in neutral, Key in the "ON" position, Ignition switch in the "RUN" position and possibly have the choke on if it cold at start up.
I think the machine is new enough that it has the start in gear feature. This allows you to start it in gear by applying the hand brake instead of putting the machine in neutral and following the above procedures.
I will add though that I personally find it much easier to pull start if the machine is in neutral. Course I am pull starting a 400 or a 500. I also like to gently pull the starter rope until just after the compression stroke. Then let the rope back in and pull as hard as I can. Seems to allow me to get some momentum going and it usually starts on the first pull.
SJ
Old Aug 17, 2009 | 04:18 PM
eggenz7's Avatar
well i finally got it to run. had to replace the spark plug boot and the thing fired right off. have to get the carb to stop leaking fuel and i can start putting the body back together. anybody have any ac 300 pastics laying around? need both of them and a front rack
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
