X2 tailgate cables
One of mine did the same thing. I bought 2 new ones......one to replace and the other a spare. When I tried to remove the screw from the tailgate side of the cable, it wouldn't back out......so I just cut the bad cable and left it alone using one cable and it works fine. I think the retainer inside the tailgate was backing out also and wouldn't allow me to remove the screw completely. As for warranty on your situation......who knows...all you gotta do is ask. Good luck....NoJoke
I had that problem and got new ones under warranty. The reason mine did that was because the screws holding each end were too tight, so on closing, rather than pivoting at the screws and the cable folding slightly, the screws held the ends tight, so the cable did a lot of bending, causing the broken wires as you have. Keep the end screws loose, and be more careful when closing, ensuring that the cable gets into a good position.
Ya, from the schematics on Motorcycle Parts, Motorcycle Accessories ? BikeBandit.com thats the Nutsert, Hex where it connects to the box but I cant see any retainer where it connects to the tailgate end.
craacker
Sep 9, 2015 04:32 AM
