X2 tailgate cables
Old Aug 16, 2009 | 11:21 AM
19TankHead60's Avatar
Default X2 tailgate cables
Is this something I can claim under warranty? Or is there a better fix for this?
I just found it so I hadn't put much thought into it. It's only 14 months old. Would hate to have to replace new cables every year.
Old Aug 16, 2009 | 12:19 PM
NoJoke's Avatar
One of mine did the same thing. I bought 2 new ones......one to replace and the other a spare. When I tried to remove the screw from the tailgate side of the cable, it wouldn't back out......so I just cut the bad cable and left it alone using one cable and it works fine. I think the retainer inside the tailgate was backing out also and wouldn't allow me to remove the screw completely. As for warranty on your situation......who knows...all you gotta do is ask. Good luck....NoJoke
Old Aug 16, 2009 | 02:12 PM
Kind of surprised. Haven't had any issues with the X2 or the ATP which has the same setup. I'd ask also about warranty.
Old Aug 16, 2009 | 08:17 PM
bad87gn's Avatar
I had that problem and got new ones under warranty. The reason mine did that was because the screws holding each end were too tight, so on closing, rather than pivoting at the screws and the cable folding slightly, the screws held the ends tight, so the cable did a lot of bending, causing the broken wires as you have. Keep the end screws loose, and be more careful when closing, ensuring that the cable gets into a good position.
Old Aug 16, 2009 | 10:19 PM
I'll have too look for my warranty paperwork now. I can handle this kind of claim. Thats a good diagnosis. I'll be sure and adjust for that in the future. I can't go see right now but I don't remember the eyelets having any movement to them. Screwed tight. Was it a pain filing a claim for such a small amount (8.33/ea)?
Old Aug 16, 2009 | 10:37 PM
Ya, from the schematics on Motorcycle Parts, Motorcycle Accessories ? BikeBandit.com thats the Nutsert, Hex where it connects to the box but I cant see any retainer where it connects to the tailgate end.
Old Aug 17, 2009 | 05:48 AM
700 sportsman's Avatar
I would consider finding some stainless steel cable, and crimp on eyelet's to make your own, and the SS would be much stronger and more durable IMO
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
