Removing Scratches?
Old Aug 16, 2009 | 11:27 AM
87250xman's Avatar
Default Removing Scratches?
How do you remove scratches from your plastics?
Old Aug 19, 2009 | 07:53 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
You don't, wear them with pride.
There is a product called PC Plastic renew where you basically sand the scratches out and then coat with many coats of a clear sealer, but it takes lots of coats and the sealer will eventually flake off.
Best solution I've found if you don't want to see the scratches is to only get camo bikes. I know that I've got to have scratches all over mine - you just can't see them.
Old Aug 27, 2009 | 09:59 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Two things helped mine. First, run a torch over it about 6-8" out and be careful to avoid the fuel tank, seat and stickers. Second, colored wax helps some.
These aren't miracle cures but do get rid of the small stuff or at least makes them less noticeable.
Old Aug 27, 2009 | 09:40 PM
Originally Posted by Raptorlegs
be careful to avoid the fuel tank.
Old Aug 28, 2009 | 08:10 AM
Raptorlegs's Avatar
T Rex Rider
lol! Thank God that's one I didn't learn the hard way.
The torch also helps bring back some shine.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
