SPENT A LITTLE ON MY WARRIOR
I have a 2000 warrior and on the weekend I fitted a Pro Circuit T4 pipe as well as Maxxis All Trak rear tires.
What a difference to the handling and cornering as well as the acceleration and mid range. The bike has far more quicker response. I did not rejet or drill air box etc.
Can't do doughnuts the way I did with the stock dunlops though ! does wheelie easier though.
Regards
Regards
No doubt the piston/cam route will get the biggest hp gain but also for the biggest buck.A
pipe will get u a reasonable gain which is noticable.i would go the pipe route and later u can do the engine mods.
An aftermarket pipe is only going to perform as well as you make it. If you get the aftermarket pipe, you should also rejet, and get a pro-design kit with K&N.
The biggest problem with the warrior is it's handling, you should tackle that problem first, maybe with different tires & an axle, then dump some cash into the motor
just my advice.
just my advice.
