Angle Sensor Quesion for the Mechanics
Old Aug 18, 2009 | 09:30 PM
12guns's Avatar
Default Angle Sensor Quesion for the Mechanics
I had my 06' Foreman ES lock up a time or two while running hard. I always let off to shift, but it was sticking in 3rd and flashing three times. Read online and first cleaned the plug and greased up w/ dielectric, I wasn't able to make it lock up again until I was heading back to the house. Now it does it in 4th and flashes three times! I took the angle sensor off today. Wondering if they can go out gradually or if the fail all at once. Also, can I grease the inside? Prolly not, but didn't know for sure. I will re grease the plug when I reinstall the new one, just didn't know for sure mine is bad. For $20 guess it's worth replacing. I still have warantee, so if it still messes up I'll take it in.
For the other ES owners, can you intentionally make yours fail, or lock up in a specific gear? Or if it clear my angle sensor is bad? Thanks guys
Old Aug 19, 2009 | 11:19 AM
JeffinTD's Avatar
I'm kind of just a backyard variety wrench, but...
The resistance on the angle sensor pins for the yel/blu and grn/blu should vary smoothly as the angle sensor turns (4k-6k).
You can also do some checking on the wiring with an ohm meter. There should not be continuity between the blu/grn pin on the wiring harness and ground, or from the yel/blu pin and ground.
With the angle sensor plug off and the key on, you should have 4.7 to 5.3 volts on the blk/red wire.
Otherwise I think I'd have just replaced the angle sensor and see if that is the cure.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
