1988 Trail Boss - PVT cover hole
Old Aug 19, 2009 | 12:31 PM
carl-in-nh's Avatar
Default 1988 Trail Boss - PVT cover hole
This is a 1988 Trail Boss 250 2x4.
I just got a hole in the top of the cover of the PVT.
Looks like it was made from the inside. I am going to take this apart today and have a look.
Question 1: Is this a common problem ?
Only way I can see to fix the hole is get a new cover (and make sure that whatever is causing the problem is fixed, of course).
Question 2: Until I get the new cover, is it sufficient to seal the hole temporarily, eg. with duct tape, or is there some consideration I am missing ?
Thanks for any answers/advice.
carl
Old Aug 19, 2009 | 05:11 PM
eggenz7's Avatar
just needs to be water tight. find out of the belt is starting to shred of if a bolt is loose causing it to hit the clutch. if it were me i would put jbweld on it and call it good.
Old Aug 19, 2009 | 05:49 PM
carl-in-nh's Avatar
Thanks for the advice.
Finally got the cover off (the old bolts were b**ch to get off; I finally had to cut the heads of 3 of them), and determined that it is not the belt but the clutch (the hole is outboard on the cover, over the clutch).
Not sure how that happened (my guess is I inadvertently leaned on the cover the time I got into a steeper than intended angle while negotiating a gully), but I am planning to do just what you suggest: patch the hole and learn the lesson.
Cole Hadden
Jun 15, 2025 09:05 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Captjay
Jul 23, 2015 12:33 PM
Gnuters
Jul 19, 2015 10:03 AM
Coryco
Jul 6, 2015 07:30 PM
